Dyno Results
Old Jul 2, 2008 | 02:17 PM
toaliosis's Avatar
Default Dyno Results
Last Wednesday at a local bike night, they had a mobile dyno for $25 for one pull.
I was curious what the old girl would pull with her 23,000 miles and the mods done to her.
Mods:
Jetted? (Guy running dyno was 99% sure it was)
Two Brothers Exhaust
K&N Air Filter
New Iridium Plugs
-1 Front / +3 Back
I wish I would have cleaned/sync'd my carbs over the winter, but gives me something to do this winter.
4th gear pull results:
98.4 hp @ 13,232
41.7 ft*lb@ 11,281
Attached is a copy of the print out.
[IMG]local://upfiles/8323/69AE63737FE64435886466C0BF093453.jpg[/IMG]
Old Jul 3, 2008 | 09:26 AM
MartiniRossy's Avatar
Default RE: Dyno Results
I would say it probably is jetted, I've heard that the K&N combo'd with a non-OEM pipe and with stock jets isn't real great. Would be something to test though I guess. Ifyou ever find out, post it up, I've wanted to do a K&Nand jets too, all that I have on my F4 is an M4 slip-on.
Old Jul 12, 2008 | 09:36 PM
senergy's Avatar
I got my 2000 CBR F4 dyno'd yesterday, staintune Slipon and K&N filter. 101hp. the Air to Fuel ratio clearly shows you that the without jetting the K&N filter is not good. The mechanic dude said that if I put the stock paper filter back on it will get 3-4hp more, Or get it jetted. think I will take the cheaper option.
Old Jul 13, 2008 | 09:42 AM
toaliosis's Avatar
Post up the data/graph from your runs now and then your ones with out the K&N filter.
Old Jul 13, 2008 | 05:36 PM
senergy's Avatar
here is the graph with the staintune and K&N, I was going to swap the filter and get it dyno'd straight away but I got lazy.. maybe some time before I get back to the dyno.
Old Jul 14, 2008 | 10:51 AM
toaliosis's Avatar
Assuming that the bottom curve is your torque output...what is wrong with it? Why is it so wavy?
Old Jul 14, 2008 | 05:03 PM
senergy's Avatar
the bottom line is not torque, its Air to Fuel Ratio (AFR). As close to 13ish as possible is good, as you can see from 90-106km/h there is too much fuel and not enough air, so needs to be jetted with smaller jets or most likely the air filter needs replacing as its running too rich.
Old Jul 16, 2008 | 04:07 PM
Thats some interesting data. The only dyno runs I've seen are behind the pub when town has there local bike rally weekend haha! Nothing funnier than a bunch of drunk dumbfu**s arguing about who's bike has more power! I would assume that the air to fuel ratio is determined by an exhasut gas analyser detecting hydrocarbons in the exhaust? I would say the rich run situation should try to be remedied by increasing intake airflow rather than leaning the jets no?
Old Jul 19, 2008 | 10:39 PM
bkmiller120's Avatar
How would one find out how to get ones bike jetted? And also, is the motor the same on a 2001 F4 as the 2000 F4? I'm new to the game. Going to school to open a shop. Need as much info as posible thank guys peace.
dragginazz
May 24, 2009 10:48 AM
Ratinacage
Aug 4, 2008 09:47 PM
stunter411
Apr 24, 2008 12:16 PM
Hatebreed
Nov 12, 2007 04:16 PM
Capone
Sep 16, 2007 01:26 PM
