Dim the Lights!
Old May 27, 2010 | 01:40 PM
emefef's Avatar
Question Dim the Lights!
I've got led tail/brake lights and separate led signals. I have resistors in the signal light circuits which work well to control the flash rate.
The issue is with the brightness of the tail/brakelights. The tail lights are fairly bright on their own, which is great for increased visibility, but the difference between the tail lights and brake lights isn't that great. I want to just dim the tail lights a bit so when the brake light comes on it's more obvious. I should be able to just put a resistor across the tail light circuit, right?
Old May 28, 2010 | 12:01 AM
dmcb2120's Avatar
yep a 330 ohm should be enough
Old May 28, 2010 | 10:30 AM
emefef's Avatar
I'll give it a try - thanks!
xankriz
Apr 2, 2012 03:02 PM
fordfenatic09
May 17, 2011 10:40 AM
deerslider
Aug 24, 2009 08:23 PM
Ocelaris
Dec 7, 2006 02:14 PM
Moe Blike
Sep 12, 2006 12:40 PM
