couple quick technical questions
I don't have a manual and there's a few pieces of information I'd like if anyone might know off the top of their head...
Torque rating for the front wheel axle bolt.
How much engine oil
torque for top tree clamp bolt (middle)
also, anyone know of a good way to get the damn decals on the fairings off? heat gun?
thanks
How much engine oil
thanks
RE: couple quick technical questions
Front axle torque: 59Nm
Front axle clamp bolts: 22Nm
If your talking about the nut in the middle with the black plug its the steering stem nut and it should be 103Nm
The decals are a pain in the ***....i did have some luck with a heat gun, however, its still a pain in the ***.
Move slowly and heat it evenly, the larger the pieces the better off ya are in the long run, even if it takes longer initially you'll save alot of time.
nondem
03-23-2006 01:06 PM
