Converting headlights...?
Old Jan 23, 2008 | 11:12 PM
G3NESYS's Avatar
Default Converting headlights...?
Can you convert the headlights on a 1999 F4 to the style of the 01+?
I dont know for sure what its called, maybe the upper fairing, or front fairing... but basically what im trying to say is can you change the whole plastic peice that holds the headlights, windscreen and all that and just switch it with a 01+ model? it looks like the line where they bolt on is the same shape so i didnt know if you could just simply unbolt the F4 one and put on a F4i one...
Old Jan 24, 2008 | 08:20 AM
Bumble Bee's Avatar
Default RE: Converting headlights...?
I don't think is a direct bolt on conversion. I have seen F1's and F2's with 600RR plastics,but it takes some fabercation to make it work. The ram air inlets are differant on the F4's and the F4i"s so is the cluster. I'm not a big fan of the looks of the F4i front end so I would never want to do this conversion.
Old Jan 24, 2008 | 10:19 AM
DonEverett's Avatar
you would have to change the upper fairing, headlight, gauge cluster, fairing support, and air inlets at the very least. You might be able to find someone to custom fit the headlights in too, but it might be cheaper to just buy the parts off a crashed f4i.
DecaturF3
Jun 24, 2013 11:55 PM
JuanO809
Sep 7, 2010 07:25 PM
JLeosnow
Jun 27, 2006 05:35 AM
JLeosnow
Jun 17, 2006 02:57 AM
