Clutch dragging?
Old Aug 2, 2012 | 09:36 AM
Raptor5150's Avatar
Default Clutch dragging?
This morning i pulled into school into the usual sidewalk spot.. as i was stopped i held my clutch in so i could shift to neutral.. so i pulled up alittle on the gear leaver trying to get into neutral and i heard a rattling sound and the gear leaver felt like it was pulsing.. i had to push down on it like twice to get it into first and finally into neutral..
was this clutch dragging or somthing else and what can i do to prevent that..
my clutch lever was all the way in.
Old Aug 2, 2012 | 02:30 PM
gotcbr's Avatar
Could be ok. The bike protests if rpms are over a certain point when trying to shift into lower gears.
Otherwise, your shift cable could be loose & not allowing full disengagement.
If overly worn, you could get the same symptoms as well. However, the F4 clutches are tough & tend to be very long wearing...that is, unless they've been abused.
What type of oil are you using & how old is it. Believe it or not, fresh appropriate weight oil can make a huge dif in shifting.
Old Aug 2, 2012 | 03:00 PM
Raptor5150's Avatar
Oh yeah.. i forgot i did rev it to my friend that was standing by me.. but im pretty sure the revs were idle when i attempted to shift into neutral.. i didnt just REV it hard and then pop into neutral.. but whatever lol hasent happened again so ill try to be easier on the clutch.. i mean its hard as it is when traffic gets going and someones stupid and slows.. i like to ride the friction zone with alil RPM and when thats engaged it likes to get going faster (its so hard to explain)
ill hold the clutch in a bit and rev to get going then let it out and if someone slows down during that ill have to pull the clutch in right away if im on someones *** at a light thats bad because i cant just brake because i dont want to stall out.. so i ride the friction zone until i have the space to full disengage the clutch.. because of that small difference in speed disengaging the clutch does..
so ill try to do that less so i dont wear the clutch.. i really hope someone understands what im talking about..
Old Aug 2, 2012 | 03:37 PM
polish man's Avatar
U only wanna do that if ur tryin to launch your gonna wear it out prematurely if your doin what it sounds like
Old Aug 2, 2012 | 08:53 PM
Raptor5150's Avatar
Well if im in neutral and i let go of my clutch it kinda sounds like.. i dont want to say rocks tumbling around.. but kind of like it.. (like a rattle) and it goes away when i pull in the clutch..
what is it? lol..
EDIT: aparently its just the clutch basket and its normal..but yeah on sunday i might do an oil change..
grantcbr600f
Jun 7, 2012 09:25 PM
SPR-GRN
Street Skills
16
Jun 3, 2011 10:57 PM
fbpsb82
May 18, 2010 12:56 PM
flyingfree9
Apr 14, 2010 08:15 PM
dj02954
Sep 25, 2007 12:03 AM
