clunk noise when accelerating
Old Jul 12, 2009 | 08:24 PM
Jutsterl14's Avatar
Default clunk noise when accelerating
So I thought my chain might have been loose and been hitting a little bit while i was accelerating, but after i tightened my chain i still noticed the same noise. It seems to be coming from my left foot peg area, and it happens when I accelerate through 1st gear to 4th. The clunking noise will happen about 3 or 4 times and then stop, then it will do it again when I shift up. I will hear it every once and a while in 5th and 6th gear but not much. Help please, I want to get out and ride.
Old Jul 12, 2009 | 10:56 PM
Jinx's Avatar
Maybe your chain is too tight, or not lubed enough. Same thing happened to me under both those circumstances.
Old Jul 13, 2009 | 05:08 AM
CRwreckz's Avatar
Maybe by being loose you stretched the chain (loose in some spots tight in others). Check your slack the rotate a bit and check, etc.
Old Jul 13, 2009 | 12:38 PM
cbtrez's Avatar
I noticed the same when i do really aggressive breaking with my bike.
I adjusted my chain to spec. I think it use to do it before but i had the plastic oem chainguard which make it not as noticable as it now is. Just have to lighten up on the brakes i guess.
Old Jul 14, 2009 | 03:50 AM
catatonic's Avatar
Sounds like the clutch to me, same thing going on with my bike currently.
Old Jul 14, 2009 | 04:37 PM
supras4lyfe's Avatar
I think ive got the same problem....its loud and other people can hear it driving behind me....it also makes the noise when the clutch is in an im deaccellerating...mine just started 5 days ago. I also just tightened the chain recently. I dont like the sound of it being a clutch issue. my bike has 19k on it.
Robert Peczkowski
Nov 21, 2014 07:46 PM
zero1niner
Jul 10, 2011 05:50 PM
speedyfreak24
May 30, 2009 08:19 PM
89ls1
Mar 5, 2008 03:06 PM
infamous01
May 27, 2007 04:15 PM
