charging system
Hey guys,
I'm having a problem with the charging system on a 99 600 f4. Recently changed the rectifier and the stator and was working just fine until today. Only getting 12.25 v back into the battery when rev at 5000 rpms. My connectors are also new. Only wiring changes I've made was the tail light integrated with the turn signals and the front turn signals modified. These were done through the instructions provided by the parts. (Could these mods be the problem?) Otherwise no other changes. Running out of trouble shooting diagrams. Please help.
Thank you, I will try this out. I checked the manufacture website on the specs on their product and it says that the voltage put back into the battery is 13.5 - 14.5 v through out the range. It was running around there for about a month then all of a sudden it went down to 12.3 at idle then 13.6 - 14.0 v @ 5000 rpm. I have a feeling it's a bad connection. The link will help to make sure I'm doing the diagnostic correctly.
Thanks again.
Thanks again.
