Cage
Old May 2, 2006 | 09:42 PM
SCobraVT99's Avatar
Default Cage
How hard is it to mount a frame cage on a 2000 F4? Anyone know? Do they bolt right on, or do you need to do any welding or anything like that?
Old May 2, 2006 | 10:55 PM
DThompson's Avatar
Default RE: Cage
It should bolt right up but you will have to cut the plastics in the same spots as the Frame sliders. There shouldnt be ANY welding involved
Old May 3, 2006 | 02:23 AM
cbr_racin123's Avatar
Default RE: Cage
No welding it bolts up. You have to cut frame slider holes where the front motor mounts are and a small hole at the bottom of the fairing. where the two sides of the cage connect at the bottom.
Old May 13, 2006 | 03:19 PM
f4istunna's Avatar
Default RE: Cage
Is it new or used? If used you might have to play with it a little they get tweaked pretty easy. What brand did you go w/?
Old May 13, 2006 | 11:20 PM
Mike_Stunts's Avatar
Default RE: Cage
buy a cage from www.PNKAGES.com my buddy makes em and those bitches dont move
Old May 14, 2006 | 12:43 AM
f4istunna's Avatar
Default RE: Cage
looks like a pretty good design from the pics, for the f4/f4i
Old May 14, 2006 | 03:44 PM
Default RE: Cage
ya. he has done a lot of refining on them. he doesnt cross under the bike like 905 and FI does. he mounts them to 3 mounting points on each side of the frame. but the secret in not letting them bend are those sliders. they are placed about 2 inches inside of the cage so there is not chance of breaking those off.
Tall Boss
Feb 6, 2010 10:12 PM
purdueplaya149
Dec 11, 2006 09:30 AM
