blew fuse where is it
Old 04-23-2010 | 11:35 PM
vain1's Avatar
Default blew fuse where is it
basically i bought this bike and the previous owner ran some led lights for the liscense plate off one of the rear turn signal hookups..i was trying to run some new leds for the liscense plate as i relocated it . I must have touched a wire together or something but i think i blew a fuse because now the tailights,brake lights and the front dash lights dont work and the turn signal relay doesnt click or light up on the dash neither does the green neutral light .....so my question is where is the fuse for this? does this bike have fuses like a car if so where the **** are they or is it one of those relays under the seat? and how can i test without replacing each relay? the only wires that where exposed at the time were the green and white wire that would originally be one of the rear turn signal clips. thanx please help just trying to locate fusebox if there is one .
Old 04-24-2010 | 05:30 AM
dmcb2120's Avatar
Whats up my fellow Michigan man. There is a box under the seat with like four 4 fuses and maybe some spares in it behind next to the battery.
Old 04-24-2010 | 11:14 AM
gotcbr's Avatar
+1 They are red 10 amp fuses. The main is a 30 amp.
Old 04-27-2010 | 01:27 AM
vain1's Avatar
Default thanx
thanx guys i found em. actually looked at the box a couple times but ended up taking every bit of plastic off and the gas tank before realizing i was staring right at it ......
chase
07-16-2010 07:24 AM
Dirtytoes
04-24-2009 03:34 PM
lamby
07-18-2007 02:04 AM
bigginzbusa
07-28-2006 07:34 AM
ox.
05-26-2006 12:13 AM
Quick Reply: blew fuse where is it
