Bad fuel economy on an F4i
Old Oct 19, 2025 | 08:44 PM
iosbuster's Avatar
Default Bad fuel economy on an F4i
Hello guys.
I was hoping you could help me with an issue i have with my Honda f4i.
I am having really bad fuel economy with my f4i. I have black smoke when redlining or when at high revs. And you can really smell the gasoline.
The fuel economy is around 13L/100km or 18 MPG (Really bad...)
Here is the stuff I have tried:
  • Changed the air filter
  • Checked the sparkplugs and the wiring harness for the sparks (all fine, but changed them out anyways)
  • Changed the coolant temperature sensor for a brand new OEM one {I thought the electric choke was causing the rich fuel mixture because of the bad Coolant temp sensor)
  • Checked the injectors (All fine)
  • Checked for leaks (No leaks)
The FI light doesn't come on and the bike runs just fine. It starts fine and it doesn't "cough" when idling. The power is a bit off because the fuel mixture is rich but I don't know what causes it to be rich.
Any help would be great.
Thank you in advance <3
Last edited by iosbuster; Oct 19, 2025 at 08:46 PM. Reason: Adding aditional information
Old Oct 20, 2025 | 11:23 AM
Welcome to the forum, how many miles are on it?
I would be starting with compression and valve checks, the valve clearances tighten with mileage.
Old Oct 21, 2025 | 03:49 AM
iosbuster's Avatar
The mileage is around 35 500 miles.
Old Oct 21, 2025 | 10:31 AM
Thanks, I would certainly check the valves as they will need doing if they have not been done before followed by a compression check to make sure the smoke is not oil slipping past the rings and getting burnt. Then proceed from there.
Old Oct 21, 2025 | 10:50 AM
iosbuster's Avatar
Wouldn't the smoke be blue if it was oil being burnt?
Old Oct 21, 2025 | 11:09 AM
Generally yes, but can also be the cause of black smoke.
One other point, have you checked the FPR, I cant see it in your steps above?
Old Oct 23, 2025 | 07:08 AM
iosbuster's Avatar
It seems that changing the FPR is the most obvious way to go about solving the fuel problem. I didn't check it. Chekced the oil, the bike is not using that much oil. Everything is normal there.
Gonna change the FPR and hope for the best.
Old Oct 23, 2025 | 08:33 AM
Pleas let us know how you get on, there is a flow test that you can do identified in the manual.
Philly_Oskar
Jun 22, 2022 10:16 AM
steve1975
Jul 28, 2019 02:20 PM
Vhandyside
Aug 2, 2016 04:52 PM
Cbgsandy
Jul 31, 2011 04:02 AM
abelg
May 11, 2009 06:11 AM
