Acceleration issues
Old Feb 16, 2026 | 09:45 AM
Azzman's Avatar
Originally Posted by aarolew78
I truly don’t believe that the ram air system is adjustable, the amount of air entering is proportional to your speed. I would start simple, fuel filter in tank, fuel filter under tank, check and make sure the hoses are are connected correctly especially the ones for the carb bowl vents (this was my issue) check for cracks in hoses or splits near clamps.
check for vacuum leaks near intake boots with a carb cleaner or starting fluid
maybe see what the plugs look like, I’m sure they probably look fine given you only have a big in a small portion of the rpm range.
Thanks mate, I will give that a go and hopefully get some progress. Appreciate the guidance.
Old Feb 16, 2026 | 09:52 AM
aarolew78's Avatar
Absolutely, if you need any photos I may be able to help, but mine has a pair system delete, DAI valve delete and the carb coolant line delete, so I’m running the bare minimum (when I bought the bike it was all annihilated and couldn’t be salvaged)
let me know what you find out.
Natedogg
Apr 29, 2024 02:02 PM
Nick Smith
F2 Tech
Jun 16, 2023 06:27 PM
sjwendte
Mar 8, 2016 08:19 PM
98formulaLS1
Apr 25, 2013 10:06 PM
Kuroshio
Sep 14, 2009 01:40 PM
