99 CBR600F4 Battery drains too quickly...
Ride the bike. When you get home check the charge of the battery. If it is low then it might not be charging properly. Makes ure all of the connections are good.
Leave it sit, and go out to it next time. If the battery is lower than it was when you stopped you have a leak. Then you just have to play hunt the leak. Start with any aftermarket wiring. After that... well it could be anything. I guess you'll just have to over the bike looking for things. :-/ not much fun. Look for worn wires between the battery, fuses and keyswitch... not much fun.
