600rr swing arm conversion brake caliper help
Old Jan 16, 2006 | 07:43 PM
billmacomber16's Avatar
Default 600rr swing arm conversion brake caliper help
Ok I have a f4 and I just got a 600rr swing arm I know you have to change the caliper and bracket but do you have to change the brake master cylinder or can I just get a new brake line made the reason im asking is because there is a 600rr brake caliper and bracket on ebay with no master cylinder so will the f4 brake master cylinder work with the 600rr caliper
Old Jan 19, 2006 | 03:14 AM
spldrong's Avatar
Default RE: 600rr swing arm conversion brake caliper help
the brake calipers are exacly the same besides color.. either master cylinder will work with each.. I have a 600rr rear caliper on my f4 because I like the gold. i hope that helped.. also i would just buy a 600rr rim and use that to avoid having to modify anything.. but they should all work without mods.. if you need any parts E-mail me at SPLDRONG@HOTMAIL.COM I have many cbr600 parts.
send some pics when you are done.. i would like to see a f4 with a 600rr swing arm.
Old Jan 19, 2006 | 01:04 PM
Thanks allot man I check at the hydraulic shop and see if that can make me a longer brake line and maybe use braded lines. If some one has a 600rr rim and axel for cheep I would gladly use them if not ill have to make the shims. And if any one has a 600rr caliper bracket that would nice too im looking on ebay and there are a few im watching
Old Mar 13, 2006 | 01:41 AM
chaos321's Avatar
Are you saying the 600rr swing arm is a direct bolt on to the F4/F4i? Does that include the shock and linkage? Give more info, this has really peaked my interest! I have never messed with the 600rr, only the F4 and F4i. Thanks
__Z__
Dec 17, 2009 01:31 PM
__Z__
Sep 11, 2009 03:29 PM
billmacomber16
Jan 17, 2006 06:45 PM
