3 issues, 99 f4
Old 04-01-2011, 05:02 PM
mooseboy's Avatar
Default 3 issues, 99 f4
First, at higher rpms the motor like cuts out, in and out, im gonna clean the carbs and see what happens.
Second, the gauge cluster wont work, there are no blow fuses? Naybe a wiring issue or possibly ruined cluster?
Third, turnsignals wont blink, the running lights work but when I press signal button,they just stay off? Possibly just the signal relay?
I dont want to just start throwing money at is so I guess let me know if you have any ideas
Thanks
Adam
Old 04-02-2011, 09:07 AM
Avi's Avatar
Avi
Avi is offline
well, about the last one, from my own experience try to open the left switch housing and clean it up. I had the same problem, replaced the relay after some cleaning. after that didn't help either, I took it apart piece by piece and cleaned it all. after that it worked. make sure you follow what you are taking apart so you can put it together.
about the first problem, I know a guy who had a similar problem, and it ended up being one of the hoses that got loose from the airbox.
about the gauge cluster I can't really help, except for saying there is a fuse box for the bike's electronics. most likely under the seat, but I have never actually looked for it.
Old 04-02-2011, 12:59 PM
mooseboy's Avatar
ok thanks man i will look into that.... anyone else have any ideas?
Old 04-04-2011, 11:20 PM
mooseboy's Avatar
hellllooooo?
Old 04-05-2011, 12:00 AM
jbtat2's Avatar
I had a similar problem w my gsxr with the motor cutting at high speeds. It was the fuel pump. Check lines and filter first. Small blockage makes to little fuel at high speeds. When my signals did that I just sprayed wd40 in the switch. Cleared it right up. Hope that helps
Old 04-06-2011, 02:43 PM
Infinity99's Avatar
apparently if you take off the petcock at the bottom of your fuel tank there might be junk blocking the gas from coming out of the tank. It would only affect you at high/rpms speeds because the fuel requirements are higher. I'm no expert but something to look into.
Old 04-12-2011, 10:56 PM
olsen726's Avatar
charge your battery and see if that fixes it. i drove my bike home with a dead battery, and it had the same sort of issues
Old 04-13-2011, 09:55 AM
nickels's Avatar
I Can't Sell On CBRF
theres a 6 or 7 inch screen standin in the tank so its possible it could need a cleaning. Possible but not likely.
Id say you got a low battery problem just bcuz f4 needs a good battery to run good.
Old 04-13-2011, 09:57 AM
nickels's Avatar
low battery will definately make your f4 have a miss
Old 04-14-2011, 02:06 PM
mooseboy's Avatar
well i threw a new battery in it and its stilld doing the same thing. its like once you get to highway speeds it sounds like its missing hardcore but if you grab the throttle it will jump out of it so its only while cruising at a certain speed on the highway? im thinking maybe like the high speed control or something in the carb? i finally got it home today so i will start looking at it this weekend
Quick Reply: 3 issues, 99 f4
