Wiring question
I have a 95 f3 just finishing up a complete frame swap. MY question is what is that bare minimum that must be plugged in to make the bike turn on/turn over? i have not put on air cleaner and a few other things. I just want to hear it turn over before i finish putting it together. This is my first swap and actaully have not done much work on bikes mostly cars. Any help/ suggesttions would be great.
PLEASE EMAIL ME AT 3hoffmanns@gmail.com
Thanks Erik Hoffmann
95 cbr 600 f2/f3 track bike going back on the road for some fun and stunts
I'd say everything needs attached besides like air filter and air solenoid valve.. It's designed to run with all the things attached so I'd connect it all so you don't take a chance burning up stuff.. Just my .02
Well if you wanted to hear just the motor turn over just gound it out and touch the lead comming off the starter to the POS+ on the battery. it will crank over. Are you trying to test the wiring on the bike? if so id just hook up everything except gas tank and get one of those hanging gas tank things (forgot what they are called). They hold like half gallon of gas and you can run without having your stock tank in the way.
how sensitive is the gauge cluster with the plastic film? mine my have seen a few rays of sun to the plastic film while i was doing the swap. Know where i can pick up a cheap replacement cluster f3 shipped to 03857
