Which wire...
Old Oct 14, 2011 | 01:19 PM
Will.Bass's Avatar
Default Which wire...
ok. im looking for the positive power wire in the harness area that provides constant power once the bike is keyed on...anyone have any ideas?
in other words, an non-switchable power lead that is not a constant (no power keyed off)
Old Oct 14, 2011 | 02:24 PM
TooBroke0029's Avatar
I can take a peak late tonight and let u know.
Old Oct 14, 2011 | 04:18 PM
Will.Bass's Avatar
that would be awesome. need for finding one is i have switchback day time running lights/turn signal leds. and the drl from the normal signals dont work for this setup. when you hit either signals, the power to the drl just cuts off until you cut the signal off.
with my setup the drl power needs to stay constant. once the signal power reaches the strip, the signal power takes precedence over the drl's..which causes the "switchback"..
Old Oct 14, 2011 | 05:38 PM
Sorry TooBroke, beat you to it... lol.
The Black/Blue wire that supplies power to the Radiator Fan motor only receives power when the Ignition Switch is turned on.
Old Oct 14, 2011 | 07:12 PM
Will.Bass's Avatar
Black/blue? Awesome dirt! Ill let you guys know what i come up with
Old Oct 14, 2011 | 08:51 PM
Will.Bass's Avatar
ok. got it and traced it back to the fuse box....
i was going to tap the new wires onto that terminal. but it looked about impossible..but i was still able to pull the terminal to make the rest of this easier..
then i started to mock up the wires i was installing and realized adding 2 wires onto a single wire was going to be a bit cluttered, so i only added one..
finished solder..
small shrink wraps
big shrink wrap
and finished. (minus putting the black plastic and wrapping the harness back up..)
i did a test once done and it does give me the power i need to make the switchback work properly. hopefully ill get a vid of them installed and working shortly...Thanks for the help guys!
redzintimidator
How-To: Mechanical
174
Aug 8, 2014 01:07 PM
aight
May 1, 2011 02:05 PM
Eckl
Jan 9, 2008 06:34 PM
speedra500
Feb 25, 2007 07:52 PM
stephygee
Dec 22, 2006 01:08 PM
