what to replace when rebuilding carbs?
Old Sep 5, 2006 | 01:22 AM
steward231's Avatar
Default what to replace when rebuilding carbs?
Hello all just wondering what all i should replace when rebuilding the carbs (ie which gasket and needles etc.)and are there any carb rebuild kits out there that everything come with it.
Old Sep 7, 2006 | 11:21 PM
LoneWolf04's Avatar
Default RE: what to replace when rebuilding carbs?
This is a very good question that probably more of us like would like to know, especially me because I was about ready to start a thread on it after turning up northing in a search. When winter hits I plan to do this along with a lot of other maintenence things such as adjusting valves and the choke cable (mine works like crap).
Old Sep 21, 2006 | 09:46 PM
steward231's Avatar
I just finished rebuilding the carbs and you dont need to replace anything. Just a good cleaning will do the trick. make sure you remove the o rings and gaskets before you clean them so as not to ruine the rubber. if you dont you will probably need to replace the o rings and gaskets... thats it. i hope it helps some. it is a pretty ez job and only takes a few hours.
Old Sep 22, 2006 | 02:18 PM
DDCavi's Avatar
Well IMO since the bike is as old as it is, may be a good idea just to replace the o-rings and gaskets anyway...
Robmarz
Jan 13, 2013 04:46 PM
trabich
Apr 10, 2012 05:51 AM
Assortedqtip
Feb 8, 2012 10:16 AM
bambam
Sep 28, 2009 06:31 PM
02f4eyeguy
Jun 28, 2009 01:13 PM
