what to do if you drop/dump? also stands questions
The proper thing to do if you dump: Hit the killswitch, pick the bike up, and tow it home. Drain and replace the oil and filter.
This is, of course, inconvenient. 99% of the time you can get away with just litting it sit upright for a few hours, so all the lubricants end up where they need to be. The reason for changing the oil is that gas almost always gets mixed in there, which reduces the viscosity. If you let it settle, it'll be "diluted" by the rest of the oil, and just burn off on its own.
YES. Severe temp fluctuations from winter weather affect the rubber and can severely decrease tire life and tackiness. If you can't store your bike in a temperature-controlled environment, at least pull the tires off and bring them indoors.
I strap my bike to a Craftsman motorcycle jack I bought at Sears, and bring the wheels in the house. Just check the straps every couple of weeks.
As far as stands go, if you're not at the track every day and using the hell out of them, then just get whatever's cheap.
When I got my bike, the front tire had deformed from sitting on one spot through at least 4 seasons. And of course everyone knows tire pressure drops through winter. So sitting on a single spot through winter would be bad with low tire pressure.
Me, I plan to ride until the snow falls
planning to get some cheap front/rear stands since i'm mostly only using them for storage except for occasional basic maintenance
here in minnesota, it gets cold starting oct but i won't be winterizing until snow hits the ground which is during nov or even at late at dec
thanks again for any tips/advice
How did you do that johnny? sounds pretty sweet I could start using that its startng to get cold here in the mornings.....
And I installed that shorty pipe its so loud, too loud, def illegal... and I THINK I can tell a slight loss in power, just not too sure... very slight... how do i fix that again?
