Way out of my league technical question plz help.
Old 08-11-2014, 09:15 AM
removebeforeflight's Avatar
Default Way out of my league technical question plz help.
So I have been looking into a replacement gauge since my trail tech went out. Not a ton of options, not a ton of info to help coax me into making a decision. I would love to put a vintage Cafe style tach/speedo on my bike but have not the slightest clue what the "ratio" for the 98 F3 would be. My question aside from the ratio and such is; is it possible to take the stock Gauge cluster and remove the actual components out of their housing and put into a different bezel/speedo housing so that I can use the stock sensor and wiring? Anyone who may be able to shed some light on this please help inform me I would greatly appreciate it.
Old 08-23-2014, 10:37 PM
gpfan1's Avatar
Normally they include the process to input the correct ratio to the speedo in the manual that comes with the part. Some use the vertical measure of wheel/tire height, which is twice the radius of the circle.
Old 09-29-2014, 02:51 PM
dead thread, bumping. still interested if I can remove part of the speedo from the "board" theyre mounted to ie; removing just the tach and mount it to a new housing/bezel?
Old 09-29-2014, 03:57 PM
sjona2011's Avatar
the only issue you'd run into, is the speedo circuit board is larger than the gauge face, shouldnt have much issue with the tach though.
i was going to upload a pic to show you, but photobucket isnt cooperating right now.
Old 09-29-2014, 04:27 PM
sjona2011's Avatar
Old 09-29-2014, 07:55 PM
Originally Posted by sjona2011
Wow I didn't expect that. I'm not too worried about the speedo. The circuit board isn't too much of a worry for me, I may try to incorporate it into a housing of some sort with my trail tech vector. So, it's definitely possible..
02f4irider
02-08-2009 08:49 PM
amnesia
11-07-2008 08:00 AM
M RR C
08-31-2008 02:41 AM
voodoochyl
02-06-2008 10:39 AM
Hayden06F4i
08-14-2007 02:43 PM
Quick Reply: Way out of my league technical question plz help.
