Vent tubes
Old Oct 25, 2009 | 10:23 PM
elchapor's Avatar
Default Vent tubes
So lately i've been having some problems with my 98 cbr. It sometimes leaks fuel when runnning, out of somewhere, i cant tell exactly. And when i used to ride it the engine woul sputter/bog down under hard acceleration no matter which gear i was in... I've been told that my vent tubes might be cloggged but i do not know where these are located. Could you guys guide me in the right direction (maybe a diagram or pic?) Thanks.
Old Oct 25, 2009 | 11:29 PM
Kuroshio's Avatar
Could be the fuel flow is restricted. Could cause all of the above. But you're talking about a lot of tubes here.
Easiest start would be to start at the gas tank, follow anything rubber from it, disconnect them one at a time and blow compressed air through it. Check the fuel filter too. Also a little history behind your bike would be helpful.
Old Oct 26, 2009 | 09:55 PM
elchapor's Avatar
So i took the tank off, and blew compressed air through the two hoses which are in the rear of the tank. I also inspected the spark plugs which are ok and I replaced the fuel filter. Bike still has the same issue under hard acceleration. The bike had sat for a while outdoors, should i dive right in and take the carbs apart to clean them???
Old Oct 26, 2009 | 10:08 PM
Kuroshio's Avatar
You can try Seafoam before carb cleaning. If it improves then you can decide whether to go with Seafoam or do a thorough carb cleaning.
But it could also be a lack of air. Another thing to try before cleaning the carbs is take the air filter off. See if it runs any better.
Btw when I suggested the compressed air I meant the fuel lines from the tank -> fuel filter -> petcock -> carbs.
justice1327
Jul 24, 2013 08:52 PM
To_Endanger
Jan 28, 2011 03:32 PM
jim roberts
Aug 3, 2008 05:05 PM
getofobulus
Jun 15, 2005 09:46 PM
