Valve stem question
Valve stem question
Went to put some air in the rear tire and the valve stem came apart. Im wondering what type of valves these bikes have. I cant tell from the schematics if it is the screw type or the press fit type. And if it is the press type do any of you know if I can install and remove them without a valve stem removal tool. Thanks.
The stems are similar to cars, but just a bit shorter. I recommend the metal stems too just to prevent things such as what happened to you. The stems crack and fail if not replaced.
http://www.amazon.com/Drag-Specialti.../dp/B002GMYWHM
