upgrade issue
Old Aug 28, 2009 | 11:19 AM
johnnyx's Avatar
You guys are bandaging the issue. The filter and exhaust shouldn't cause the mixture to go so lean as to cause that. Carb cleaning \ balance \ pilot screw?
Old Aug 28, 2009 | 11:41 AM
bambam's Avatar
with in 20 min you could put stock parts back and test run. that way you can be sure your fixing the right problem.+1 on given advise, our bikes are fine tuned machines, even a diff air filter can change air/fuel mix and make the bike run worse, same with exhast. Dyno stage one is recomended for bikes with k&n filter and a pipe upgrade as stated in other post. if you do the work yourself dont forget to hook up a flow meter to balance the carbs after re-jetting, an important step to get great idle and throtle response.peace
Old Aug 28, 2009 | 12:51 PM
96@cbr's Avatar
thank you for all feedback! kit will be here next week! i will post pics and hopefully a test drive vid. we will see im hoping it will run right! i love my cbr! i dont have the stock parts but i heard if i use duct tape and tape off half of the air intake so there is less air going in and if it runs better then it is running lean. we will see. keep me in your prayers!
Old Aug 28, 2009 | 12:53 PM
96@cbr's Avatar
i know iknow man! ireally hope you are wrong tho because i hope nothing else is wrong! but i really appreicaite your help! disserved was very helpful!! thanks man
Old Aug 28, 2009 | 01:07 PM
bambam's Avatar
most hondas have a duct tape allergy, dont try it. now a ninja wont run rite without it.
Old Aug 28, 2009 | 01:14 PM
96@cbr's Avatar
ok thanks
Old Aug 28, 2009 | 01:54 PM
johnnyx's Avatar
Don't they require you to run a 50/50 mixture of gasoline and super glue?
Old Aug 28, 2009 | 02:26 PM
96@cbr's Avatar
Old Sep 1, 2009 | 09:06 PM
96@cbr's Avatar
Installed jet kit carb popping went away but still not pullin like it should
Old Sep 2, 2009 | 10:33 AM
johnnyx's Avatar
Did you remember to sync everything after reinstalling the carbs? Do you maybe have to tweak your pilot screw a tad to account for the new jets?
