Turn Signals
Old Dec 23, 2008 | 11:16 PM
Ahmadi6490's Avatar
Default Turn Signals
I hit left or right and nothing. I was thinking maybe the flasher relay but what do you guys think? They will still click without the signals being on the bike correct?
Old Dec 23, 2008 | 11:19 PM
redzintimidator's Avatar
Default RE: Turn Signals
the lights on the dash shouldnt blink...i dont think they will work with out some kind of bulb attached
what are you trying to do?
Old Dec 23, 2008 | 11:30 PM
Ahmadi6490's Avatar
I just want to make sure the blinkers work, I do not have the turn signals ordered yet. But with the bike on I turn them on. Aren't they still supposted to click even without them hooked up?
Old Dec 23, 2008 | 11:56 PM
no i dont think they will...there is no load on the relays
Old Dec 24, 2008 | 01:28 AM
Hurricane rider's Avatar
with no signals at all hooked up, your light(s) on the dash wont even flash, they'll stay solid. same thing with LED signals on both ends.
Old Dec 24, 2008 | 10:48 AM
Ahmadi6490's Avatar
Gotcha, thanks guys. Can I have just the rear plugged in for it to work?
Old Dec 24, 2008 | 01:46 PM
if they are filament bulbs...yes..not LED's..there is not enough resistance in LED's to make them flash without non-inductive resistors
Old Dec 24, 2008 | 11:11 PM
Ahmadi6490's Avatar
Thanks redzintimidator
Old Dec 25, 2008 | 01:24 AM
orr...instead of the non-inductive resistors when they flash to fast you can buy a variable load signal relay...cause the resistors create a lot heat and can melt plastic....
Lowridese
May 1, 2010 01:12 AM
MrBlaze
Aug 17, 2009 02:07 AM
playb0i
Jan 2, 2009 04:55 PM
Terry954rr
Jul 25, 2008 08:32 PM
Neutron
Sep 28, 2006 02:47 PM
