Trouble starting after rebuild, few questions
Old 06-04-2011, 02:44 PM
pmb5's Avatar
Default Trouble starting after rebuild, few questions
I have an F2 I've converted to run the ram air airbox/carbs and fuel pump from the F3. It's a ground up rebuild (including the cabrs) I'm having trouble getting it start up, which i'm 99.9% sure is because the floats are sticking and flooding the motor (going to check them tomorrow).
Anyway I have 2 questions which have come from trying to get it fired up.
  1. Will/should the fuel pump stop pumping when the float bowls are full?
  2. I checked the sparks for both coils using my Cal spec CDI and UK one, they seem a bit better with the UK CDI but still a little lame. Is this usual? I'm used to looking at bigger plugs and the spark is usually much brighter.
thanks in advance.
Old 06-04-2011, 06:50 PM
The fuel pump only runs when the engine is turning over. It will slow down so that you can only feel a click or bump every 2 or 3 seconds or so. If you want to know if the floats are sticking, here is a method you can try. If you have the carburetors off the bike and there is no fuel in them, here's what you do. Attach a clean piece of fuel line to the carburetors. Blow into the end of the hose. You will find that you can blow air through them when the carburetors are in the normal operating position. If you turn them over, then you can't because the floats are holding the float needle closed. If you can still blow air through them, then one of the needles/floats is stuck or sticking. Don't use a compressor, it's too much air pressure.
As for the spark and CDI, I couldn't even begin to hazard a guess.
Old 06-05-2011, 01:43 AM
pmb5's Avatar
Thanks very much for the tip, i didn't think of trying that with the carbs. I'll give it a go before i dismantle them. As i've had to add the fuel pump to the F2 wiring that's how i've got it working, it only runs when the engine is turning over (starter or actually running). I was wondering if the F3 CDI is what actually controls the speed of the pump, i.e. throttle position or rpm dependent as my F2 CDI doent have any of that.
I guess i'll just have to test the coils and see, i'm used to looking at much bigger plugs and the spark is much bigger/brighter.
Old 06-05-2011, 10:32 AM
pmb5's Avatar
I got it going, no 2,3 floats were stuck but no real reason for them to be and no4 was still sticking. I swapped the float bowl and cleaned up the float needed and tube, that seemed to sort it.
Thanks again for the help.
jbomb
04-18-2013 06:22 AM
fish12
09-25-2010 02:20 PM
andyriot
02-13-2010 11:50 AM
tonyB11
01-10-2008 08:07 AM
streetbikestunta
03-15-2007 10:36 PM
Quick Reply: Trouble starting after rebuild, few questions
