Transmission
You can't use a shift fork from a F2. The pin that follows the shift drum is smaller. You either have a bad shift fork or a damaged shift drum. The shift fork for 2nd gear is close to the edge of the drum and can break a piece off. I fixed a F2 last winter for a customer in the shop.
