too rich, pls help!
Old 06-25-2009, 12:42 PM
johnnyx's Avatar
Are you sure all cylinders are firing?
Old 06-25-2009, 04:19 PM
blubo2256's Avatar
how do i check to make sure all cylinders are firing? When i took the carbs off, one of the valves that opens and closes when you hit the throttle seemed like it was "burnt" in an aspect.
Old 06-25-2009, 04:25 PM
johnnyx's Avatar
Ahhhhh, there's a fine clue.
If it's burnt, that means excessive heat \ carbon is getting up that high. This means it's escaping from the cylinder chamber. Sounds like you've got a blown cylinder seal. This would cause lack of compression, and thus lack of combustion. After that, all the un-combusted gas gets spit out the exhaust valves, which causes:
A) Large amounts of gas in the exhaust vapors
B) Subsequent backfires.
Sound familiar? You're lookin at an engine rebuild. Feel free to stick around for a second opinion (where the Hell are you guys?), but all the pieces seem to fit into place, here.
Old 06-25-2009, 04:56 PM
blubo2256's Avatar
How much do I look at to rebuild the engine?
Old 06-26-2009, 10:34 AM
johnnyx's Avatar
That's a hard question to answer. I'm willing to be once you get stuff open, you're gonna find a few things wrong. It all depends on what you have to replace. Also, this is a pretty advanced situation now, and you may want to enlist some help if you haven't done engine rebuilds before. It's very similar to an old car, if that helps.
T-Rich
10-02-2011 11:35 PM
marc0011
06-26-2008 07:22 PM
CorruptMind
04-26-2008 12:35 AM
bukwld360
04-10-2008 04:28 PM
eekenterprises
07-25-2007 12:09 PM
Quick Reply: too rich, pls help!
