stripping paint from fairings??..
Old Aug 9, 2007 | 04:46 PM
tho418len's Avatar
Default stripping paint from fairings??..
What should I use to strip paint off of plastic fairings???
Old Aug 9, 2007 | 05:56 PM
uglyangelracing's Avatar
Default RE: stripping paint from fairings??..
What kind of paint did you use on it? If the paint job isnt cracking or peeling I would just scuff it wet with 600 and spray over it.
Old Aug 10, 2007 | 07:34 AM
Northernfirepower's Avatar
I just used paint thinner in a big gallon jug. You just spread it generously, and once the paint starts to get soft you wipe it right off. Don’t leave it on too long because it will eat thru the plastic if it’s on for too long. I was stripping someone’s ****ty paint job that was over stock paint, the stock paint didn’t strip off. If you’re looking to paint stock painted plastic, just rough up the finish with some sandpaper and go to town.
Old Aug 10, 2007 | 09:31 AM
almega's Avatar
If the stock paint had started to chip off, how would you go about getting that off? My replacement fairings have some chipped off flecks [>:]
Old Aug 10, 2007 | 10:46 AM
tho418len's Avatar
yeah someone painted over the stock paint and its chipping off.
Old Aug 10, 2007 | 12:38 PM
You should be good with using simple paint thinner then. Just get out an old rag, some solvents, and start wiping it down. It's better to do it outside because the fumes get to you even then. I also suggest taking the plastic off and doing one piece at a time so that you don't miss the seams and makes the job a lot easier.
etdavenport
Apr 12, 2011 12:22 PM
Kuroshio
Jan 7, 2010 10:12 PM
patso
Feb 8, 2009 11:39 PM
CrackDaddy
How-To: Mechanical
Dec 5, 2008 07:23 PM
FLYOU
Sep 10, 2008 08:04 PM
