steering question
Old Sep 4, 2007 | 03:25 PM
mycat8urskidoo's Avatar
Default steering question
when im riding straight my handlebars are off to the right just a tad, bent forks or can i just loosen everything up, straighten it and tighten it?
Old Sep 4, 2007 | 05:23 PM
pacemaker's Avatar
Default RE: steering question
Look, you will notice bent forks & steering, it really affects the way a bike handles, progressively worse as the speed increases. So if its not showing any probs there. Most roads are not flat, they are curved slightly for water run off, & sometimes give the impression that your not running true. Also there is a possibility that the bars could be bent.
Old Sep 4, 2007 | 05:28 PM
they're defintaly not straight, you can see it if your just sitting on the bike not moving, as for any difference at high speeds i dont notice anything, i've only had it around 100 and it seemed fine
Old Sep 4, 2007 | 05:59 PM
Cadaver's Avatar
If you're comparing the ignition cylinder location to the front fairing stem, then ya....it doesn't line up perfectly.
Old Sep 4, 2007 | 08:51 PM
nothing to do with the ignition cylinderor the road, its obvious that something is tweaked
Old Sep 6, 2007 | 12:34 AM
LlanoSV's Avatar
could you post a picture?
Old Sep 10, 2007 | 04:28 PM
AK47's Avatar
taken whilest hes riding? smart..
Old Sep 11, 2007 | 07:27 AM
Northernfirepower's Avatar
You can loosen the lower tripple bolts that lock the forks and use a 2x2 or a tree or anything to jar the front rim to get the forks to twist into place. It takes a few trys to get it right, but it's not that hard.
Old Sep 13, 2007 | 02:12 PM
gixxereater's Avatar
Is this just while riding that you notice you are turning the handle bars to make the bike go straight? If so a possible problem is a misaligned rear tire. If the handle bars are turned right.......so is the rear tire meaning it would have to move back on the left hand side and vise/verse. A single trackvehicle will steer depending on both front and rear alignment. It's an option, if every thing seems straight but it rides crooked, then that is likely the culprit. Just a thought.
yogi4476
Aug 18, 2012 03:39 PM
akubat
F2 Tech
Aug 6, 2012 09:46 PM
CBRriderNevada
Apr 20, 2009 10:33 AM
tpgpz
Feb 8, 2008 11:13 PM
astro2269
Nov 15, 2006 08:34 PM
