steering question
on
1 Post
Look, you will notice bent forks & steering, it really affects the way a bike handles, progressively worse as the speed increases. So if its not showing any probs there. Most roads are not flat, they are curved slightly for water run off, & sometimes give the impression that your not running true. Also there is a possibility that the bars could be bent.
Is this just while riding that you notice you are turning the handle bars to make the bike go straight? If so a possible problem is a misaligned rear tire. If the handle bars are turned right.......so is the rear tire meaning it would have to move back on the left hand side and vise/verse. A single trackvehicle will steer depending on both front and rear alignment. It's an option, if every thing seems straight but it rides crooked, then that is likely the culprit. Just a thought.
