Spark plugs!!!
Old Jul 21, 2013 | 01:45 PM
Tango3921's Avatar
Default Spark plugs!!!
Hi everyone i have a 97 cbr 600 f3 and its not starting so going through all the step to clean it out and get it running again im about to do the spark plugs next any tips on how i should approach them... Thanks
Old Jul 21, 2013 | 06:44 PM
Will.Bass's Avatar
what do you mean how to approach them?
Old Jul 21, 2013 | 08:27 PM
coalminer frank's Avatar
I have a F2 which is pretty much the same bike except for the ram-air, and a couple other little things, so...................Its easier if I removed the radiator. You'll have the ram-air stuff in the way. The more room you make for your hands and tools the easier it will be.
Old Jul 22, 2013 | 07:03 AM
Mrmanr's Avatar
The way i do it is through the fairing. All you need is a good 5/8 spark plug socket with tight rubber inside,a short length extension and a socket wrench with no bearing in connector. The trick is in the way you insert and retract tools. First gently drop socket over plug then attach extension ,then wrench. Loosen,take off wrench, pull up on extension and seperate socket from extension with one using your fingers. Its easy once you get the hang of it and all you take off is engine compartment fairings. Remember it will be alot easier with a socket wrench with a missing lock bearing.
Old Jul 22, 2013 | 06:53 PM
Tango3921's Avatar
Hey thanks I just got them out today the trick with the socket helped n save me some time and yea spark plugs were black n smell like gas so I figure they were bad n the engine might have been flooded
baseballkid
Oct 4, 2012 07:48 AM
jvhjgh2006
Jun 26, 2011 02:07 AM
Carbon_cavvy
Feb 29, 2008 08:25 PM
eukanuba517
Feb 19, 2008 04:54 PM
mikey1297
Jul 11, 2006 02:42 PM
