someone jacked my key hole w/a screwdriver
Old Jun 22, 2012 | 03:54 PM
candyf3's Avatar
Default someone jacked my key hole w/a screwdriver
Well i come outside this morning and go to stick my key in the ignition and it will turn just far enough to unlock the handlebars but no further. Look down at the hole and the ignition and someone was definitely trying to start my bike with something like a flat head or a knife or something. The box looking plastic around the ignition is busted up pretty bad. There were pieces of that laying on the ground. So my question is where do i start? replace the whole thing?
Oh yeah i forgot to mention this is my daily driver so they really screwed me over big time
Last edited by gotcbr; Jun 24, 2012 at 09:48 PM. Reason: merged back to back posts
Old Jun 22, 2012 | 06:58 PM
Stebdawgsf3's Avatar
id replace the the whole unit. you can pick them up cheap used. the only problem is you have 2 key then, but if you ordered a set from the dealer (if they still have them) then you can order the gas tank lock and helmet lock as a kit. but that is a very expensive kit. id live with 2 keys.
Old Jun 22, 2012 | 08:47 PM
candyf3's Avatar
Anyway to get it started while I'm waiting on the new ignition
Old Jun 23, 2012 | 06:40 AM
MadHattr059's Avatar
From what I'm seeing in the wiring diagrams, if you short from the red>red/black,
on the ignition switch, the bike will be able to start.
Try Radioshack for a 15amp rating rocker or push-on/push-off switch.
This will leave you vulnerable to theft, if the previous guy revisits the scene of the
crime. So use some 12guage wiring and HIDE the switch. I would get a rotor-lock or
chain, if you do decide to go this route. It might be a good idea to ALSO install (and
hide) a 30amp switch between the positive lead on the battery and the battery itself.
Or put up with the inconvience of pulling the seat and doing it manually,
for those times you are parked for any length of time. Try to do that as un-obtrusively
as possible, so you don't telegraph what you're doing, though.
It's a shame that it's your daily commuter, or I would recommend haunting ebay for
an ignition, gas-cap, helmet-lock set. I found mine for less than $100.
Old Jun 23, 2012 | 08:47 AM
Sinistry06's Avatar
I second the rocker switch till you can get a new set. Just keep it well hidden
Old Jun 23, 2012 | 09:07 AM
candyf3's Avatar
Does the new ignition just plug in?
Old Jun 23, 2012 | 10:32 AM
underground-mpyre's Avatar
Here is what I use a round key lock. So that thieves have a lot harder time stealing my $h!t. No more @-holes trying to start your bike with a screwdriver.
NEW 91-94 CBR600 F2 & 95-97 CBR600F3 IGNITION SWITCH ROUND KEY | eBay
Sinistry06's Avatar
Yes I do believe so. I wanna say there is about a foot of wire before the plug.
Old Jun 23, 2012 | 01:32 PM
Yes it plugs into a socket, do all of your temp wiring on the side with the old switch, so you don't damage the harness.
Good luck, Ern
Old Jun 23, 2012 | 01:35 PM
candyf3's Avatar
The only wires i can see coming out of the bottom of the ignition are going up behind the dash cluster where the gauges and neutral light is. Is the plug behind the dash?
