someone jacked my key hole w/a screwdriver
Hot wiring it to get it, to the locksmith? So, he can replace the cylinder?
Is that what they're suggesting? That's cool, a quick fix, if it can be done that way.
If you take the key he can match the pins to it.
Didn't know you could just replace a damaged cylinder. It's worth a try, I suppose.
Hope it works, Ern
Hope it works, Ern
Hope it works, Ern
Hope it works, Ern
To hot wire it can i just use a short piece of wire to make a bridge on the plug coming out of the ignition?
I would think that if you pull the plug on the harness and then do a bridge into the
harness plug.Be aware, the bike's electrical system will STAY hot until you unplug it.
So the headlight/taillight will drain the battery if the bike's not running.
If you're going to try this you might rig the jump with a switch and a couple of
bayonets or pins (whichever is appropriate) that plug into the harness connector.
Should be a quick run to Radioshack and just a couple of bucks.
Ern
Ern
I mention bayonets vs pins because I don't recall whether the harness side of the
connector is male or female. Usually, the harness plug has the male pins that the
specific component's female connectors bayonets slip over. But I won't swear that's
the case. Hence, my 'padding' my comment. Of course, if you were abandoning the
ignition switch, you could just cut and splice on the switch side of the connector.
Ern
Ern
specific component's female connectors bayonets slip over. But I won't swear that's I
Ern
Ern
Thanks
Put the switch between the red and red/black wires. According to the diagram I'm
looking at, that should do the job. I do want to add the caution...I haven't actually
done this before, so my advice is based on my reading the wiring diagram in the
Clymers manual correctly. I don't think I'm giving you bad advice or I wouldn't post,
etc., etc. If you want to be really sure, you might PM IDoDirt and have him look over
this post to corroborate my advice.
I just PM'd one of the other mods to see if he could look it over and be sure I'm on the mark.
Ern
Ern
