Some questions
Old May 1, 2008 | 12:27 AM
KoukiFC3S's Avatar
Default Some questions
Hey,
Just got my CBR and I had some questions:
-my tach stopped working for a few minutes today. I'm thinking the cable isn't properly connected. Has this happened to you?
-At 80mph on sixth gear I'm at 6.4K, is that stock?
-throttle has some play. Anyone know what section in the manual is the procedure to tighten it?
Thanks!
Old May 1, 2008 | 01:28 AM
pacemaker's Avatar
Default RE: Some questions
No, never had the problem with the tach, but its electrical, no cable, but if it happens again, check the connections (see your manual). 6.4 RPM sounds on the money, you should find the throttle cable adjustment guide under "Routine Maintenance" or "Fuel &...." depending of which manual you use.
Old May 1, 2008 | 09:03 PM
Dakarai's Avatar
I'm running about 6.4K at 80. I'd say your safe there.
cbrmonster
How-To: Mechanical
Nov 13, 2008 01:07 AM
bigboi18184
Nov 9, 2008 05:58 PM
SNOWMAN
Feb 5, 2008 08:10 PM
karty
Sep 3, 2006 01:15 AM
Paper Chaser
Aug 3, 2006 05:24 PM
