Smoking Rectifier
Old Apr 28, 2012 | 09:47 PM
TeamHennis's Avatar
New Member
Default Smoking Rectifier
Hello everyone,
I just got a '95 F3 that was non-running. New plugs and fresh gas, bike started right up. I rode if for about 2 hours this morning when it just shut off while doing 45mph. Pulled over, checked it out, eventually found that the fuse in the starter solenoid had popped. Got a new one, and it instantly popped when I put the connector back on. Poked around some more, didn't see any obvious shorts, so I tried another fuse. This one lasted a little longer, then I notices smoke coming out of the rectifier and then the fuse blew. I disconnected the rectifier, new fuse, bike started without an issue and i rode it home. When I got home, I checked the wire harness with a multimeter and the readings were all what they should be.
My question is, obviously the rectifier is bad, since it burnt up, but was that the cause of my problems? I don't want to replace the rectifier, only to have it burn up again. Any ideas? If it matters, my battery is charged to 12.4v.
Old Apr 28, 2012 | 10:49 PM
Yes, if the Regulator/Rectifier shorts out, it will blow the 30A fuse. It's a common flaw on the F3's and others as well.
Old Apr 28, 2012 | 11:19 PM
FLATBLACK740's Avatar
also check your stator voltage to manual specs
Old Apr 30, 2012 | 06:56 PM
motorcyclist's Avatar
Egypt Junior Member
check this link, this dude installed a gsxr instead
https://cbrforum.com/forum/f2-tech-9...-solved-27739/
Last edited by gotcbr; Apr 30, 2012 at 08:59 PM. Reason: Don't post inaccurate info re: Honda.
rpmraper
Oct 7, 2011 09:33 AM
rpmraper
Sep 11, 2011 09:51 AM
ionutchelu
Sep 17, 2008 03:11 PM
jorangesquinn
Sep 27, 2007 09:33 AM
NC CBR1K
Sep 15, 2006 04:30 PM
