scratching my head to the bone
Old 06-04-2011, 10:35 PM
subduedskyline's Avatar
Default scratching my head to the bone
Hi. I'm new here and I need the Dr. House of bikes. Here's the deal- 1995 CBR 600F3. Starts right up, idles fine and even revs up in neutral, but when you put it in gear and twist the throttle, it runs up through first, shift to second and it begins spitting and sputtering like it's running out of fuel. (Fuel tank is full and pet **** is open). What I've done so far- had the spark plugs checked, carbs taken apart and cleaned (Stock carbs with stock jets), checked the fuel pump, changed the fuel filter, changed ECU, and checked the ignition coils. By "Checked ignition coils", I mean all the spark plugs are sparking. Air filter is dirty, but not dirty enough to cause issues and even if it was, these are obviously not air filter issues. The only other oddity is that the issue seems to be sensitive to outside air temp. 50-60 degrees or so, it actually runs okay, but once the outside temp gets over 70 or so, it starts acting up. HHHEEELLLPPP!
Old 06-05-2011, 12:07 AM
One other thing- It started acting up with fresh fuel in the tank and I also drained and refilled the tank, so I know it's not bad fuel either...
Old 06-05-2011, 12:12 AM
siberiancbr's Avatar
Did you check your charging system?
Old 06-05-2011, 08:32 AM
no. I know the battery charges and the headlight is nice and bright when the motor's running, so I assume it's okay... I read on another forum about a guy with identical issues and it actually ended up being because the air filter was dirty. Maybe my statement of ''obviously not an air filter issue'' was misled. Outside air temp would also make sense considdering air density at those temps. I'll run it this evening without an air filter and we'll see...
Old 06-05-2011, 08:20 PM
cgmiller83's Avatar
Is the bike warmed to normal operating temp? NO CHOKE.
Old 06-05-2011, 08:32 PM
It does it no matter what the engine temp is. I just tried taking the air filter out and running it without it... No change
Old 06-05-2011, 10:55 PM
jveach's Avatar
I found something that might help, it could be the air valve not switching over with speed like it is suppose to..... Try this and see what happens, wouldn't take long to do
https://cbrforum.com/forum/cbr-600f3...5k-rpm-101283/
look threw the post's and you will see what i'm talking about
Old 06-06-2011, 06:44 AM
my possibly answer comes from the car world since i am new to bikes....
but it may help.
is your fuel pump working properly?
the pump may be pushing enough to keep the bike running at idle, but may not have enough power to push fuel fast enough to keep it running longer at load. fuel pumps can be funny and flow enough at idle, but not strong enough to meet the demands at load. first gear could be emptying the fuel filter, and the pump cant keep up after that.
just a thought and hope it helps.
Old 06-06-2011, 08:18 AM
Will.Bass's Avatar
im almost positive that is the root cause. either that or his gauge plugs are loose...that'll do it to, exact same problem, different source
all you have to do is unplug the white 2-wire connector on the right side of the bike. along the outside frame rail below the gas tank
Old 06-06-2011, 10:30 AM
Jeffrey's Avatar
Should also take the back of the pump housing off and verify that your contacts are good.
Quick Reply: scratching my head to the bone
