rich or lean?
Old Apr 22, 2014 | 02:54 PM
JamieDenny's Avatar
Well I put the a new OEM paper filter in (was K&N) and it has almost made it perfect. With the bike running lean because of the new stainless free flow exhaust and headers it made sense to cut it back a bit and the standard filter has really helped balance it out.
Unfortunately the forks leaked oil everywhere on the test ride so i struggled to get it past 70mph (I live is the twisty countryside) but boy did that make a difference !
all of my mixture screws are 2.5.
A good way of setting the mixture screws is to use a sensitive tach that shows 1 rpm changes (the one on your bike isn't sensitive enough but they are cheap on ebay) then set the idle, adjust mixture screw #3 until the revs change, drop it back and set the idle with the idle screw again. repeat this for all 4 carbs
My bike idles nicely dead on 1250 rpm and returns to it regardless of temp.
As the paper filter made such a difference i am going to throw in the heat shield and see if that clears up the tiny hesitation around 8k.
Old Apr 28, 2014 | 04:21 PM
josiahafelix's Avatar
Ok so the orgon rain has stopped and I got a chance to look at it more, I pulled the carbs and checked the mixture screws, carb one (left) was at 2 turns, all the others were at 2.75. I changed carb one to 2.75 and there wasn't a difference, I changed all four to 3 turns out and took it for a ride, when coming to a stop it returns to idle without needing to blip the throttle now so that's better, did I richen it or lean it by turning the screws out? Shouldn't I be trying to lean it more than stock because of my huge jets?
Old May 1, 2014 | 11:26 PM
So I found out I had made it more rich by turning the screws out so today I turned them in 3/4 of a turn to 2.25 turns out, seems to run better but I'm getting some backfiring now, how do I know when too lean is TOO lean ? Last thing I want to do is melt something
Old Jun 1, 2014 | 06:50 PM
nickcp's Avatar
Do you have any idea what brand the jets are? I'm also trying to figure out when carbs are too lean..
Old Jun 2, 2014 | 09:43 AM
I don't, my jets are not stamped with any names or symbols, just the size, I went to 1 turn out from seated and it helped a bit but once it warms up it's bogging down a bit
Old Jun 12, 2014 | 05:36 PM
nickcp's Avatar
Sounds too lean.. Is it bogging at high rpms? I had a similar issue and I turned my air/fuel mixture to 3 turns out. Now it runs better, I just have to adjust my air box to seal properly, and hook up the correct intake hoses to tune it properly.
Old Jun 13, 2014 | 12:29 PM
Yea it's most certainly too lean, it only seems to bog down on the lower rpm range, up to about 6-7k, most noticeable when you try and just whack it wide open, I've began experimenting and pulling the choke in just barely seems to help a bit on the low end.
Old Jun 18, 2014 | 10:05 PM
Anyone happen to be in the Portland Oregon area? I feel like I have to ride another f3 to see if I'm just crazy or if I'm actually having an issue. I talked to a guy at a local shop and he said the a/f adjustment screws only adjust the mixture on the "pilot circuit" and would make no difference above idle, this guy is mistaken correct?
Old Jun 18, 2014 | 10:22 PM
He is more right than wrong. It actually plays a role throughout the entire range of the throttle. Having said that, between idle and 1/4th twist of the trottle. After that, it tapers off more and more until full throttle is reached.
Old Jul 8, 2014 | 01:54 PM
Ok issue seems to be fixed, i have taken this thing apart so many times im pretty sure i could do it blindfolded, striped it down and cleaned it all again just to be sure, cleaned and oiled up the boots for a good seal, set the mixture 2.5 turns out, and what seems to have made the difference is i raised the needle clip one position to the second from the top. Now she starts with minimal choke, steady idle, and is a rocket above about 5k, all this work and im about to get an f4i, cant stand the carbs
goodkookin
Feb 21, 2012 10:20 AM
GDM YO
Mar 23, 2008 06:29 PM
AchillesGone
Mar 21, 2008 01:34 PM
=Fred=
Jan 12, 2008 03:52 AM
adam833
Oct 31, 2006 02:04 AM
