Replacing the guage faceplates
Old Feb 23, 2009 | 02:27 PM
mrukus's Avatar
Default Replacing the guage faceplates
hi all, have the gauges apart, just want to replace the face plates with some fancy ones. there is a problem with getting the needles off though, it looks like the spring is attached to the needle, and i can't get the needle of the post that the spring is attached to, any help?
Old Feb 23, 2009 | 06:44 PM
SIRR1's Avatar
The needle pulls straight off the stem, then remove the face plate screws (2) then remove the face plate. The spring is below or under the face plate.
SIRR1
Old Feb 23, 2009 | 10:04 PM
mrukus's Avatar
how do you get the needle off the metal post without messing up the spring? i wasn't able to pull the needle off without pullout out the whole post. the spring came off with it. thanks a bunch
Old Jun 23, 2009 | 11:54 PM
subject6m3's Avatar
where did you get the new face plates for your guages? i have a 96 cbr 600f3 and i am trying to do the same thing.
Old Jun 24, 2009 | 06:15 PM
mrukus's Avatar
they are called illumniglo guages, you can buy them off of their site, they still sale them, if you have any questions i can help you i did like 3 more after i did mine, im pretty good at it by now
Old Jun 25, 2009 | 06:57 PM
1998f3's Avatar
+1 on the illumiglo gauges. I like the reverse glow ones where just the numbers light up, as opposed to the whole face but not the numbers lighting up.
Old Jun 25, 2009 | 08:34 PM
orangef3's Avatar
http://www.streetracerparts.com/Hond...p/srp-0720.htm go there...the gauges they sell slip over the needles...no removal required
Old Jun 26, 2009 | 10:32 AM
subject6m3's Avatar
well i went ahead and took my gauge plates off and while i was easing the needles off the whole damn pin came out of the assembly.. plus the spring on the speedometer came completely off and now it doesnt work
im getting the f4i gauges and doing that swap.. might as well since i done jacked this gauge cluster all up..
but for all you other guys that dont have this problem with the needles.. well i found out that the green color is cause of the back of the gauge faces... so all i did was use a dremel tool with a sanding head, and went to town on the green junk. replaced the gauge faces and now i can put any color light in the back ground and turn my gauges into what ever color i want. i didnt take any pics cause i was mad at the damn needles..
all in all though it was pretty simple.
Old Jun 28, 2009 | 07:53 PM
mrukus's Avatar
doh!!! i was thinking about this post as i was camping this weekend and couldn't get here in time, i did exactly what you did the first time. ruined my guages. for anybody else that cares to do it, in order to remove the needles you have to lift it past the stop, it will stop and not spin any further about 30 degrees behind the stop. make a note of that position and keep spinning the needle counter clock wise to loosen it. then once the new faces are on just push the needle back on in the right place. and don't try to put any sticky faceplates that advertise no needle removal. you will screw up, just remove the needle how i described, it will save you a headache, because none of them just slide over the needles.
akrite
Sep 30, 2013 02:22 PM
The__Rider
Oct 30, 2010 09:00 PM
bammerman
May 11, 2010 07:07 PM
JSTATL
Jul 16, 2006 03:08 PM
T02F4i
Jan 25, 2005 12:10 AM
