Removing fuel pump
Removing fuel pump
So i have a 96 f3, and its being very customized. Ive hacked off the subframe, built my own, and am lookin to free up as much space as possible. Now i know on my f2, it had no fuel pump. My f3 does. I need a new petcock anyway, so could i get a petcock from an f2(no fuel pump) and eliminate the fuelpump all together, to gain some room?
if anyone wants to follow the build, its http://www.customfighters.com/forums...ad.php?t=10206
thanks!
thanks!
RE: Removing fuel pump
I'm fairly new around here, just bought a '96 F3 in the last month, and have been lurking for a while.
Anyway, as I understand it a ram air system allows more air to flow into the carbs, and consequently can use/draw more fuel than a comparable system without the ram air. In my mind this explains the need for the fuel pump on F3s and lack of a pump on the F2s. I believe this is similar to when a turbo is added to a carbed engine. When the turbo forces more air into the carb, it also creates an increased need for fuel. Without proper(enough) fuel pressure the engine will starve for fuel.
Anybody please feel free to confirm this theory or correct if I'm wrong.
with turbocharged/supercharged FI engines you need more fuel too, solution for that is bigger injectors, or more injectors(IE. supplementary injectors). I had to go through this when i built a turbo kit for my car.
solution to this problem, bypass the pump and disconnect it. If it works,great, it works. If it doesnt work good enough, you need it.
less talk more action!..lol
Kopi Ko
09-06-2024 12:02 AM
Red97tib
CBR1000F For Sale / Found
09-03-2013 10:06 PM
