rectifier
Old Jun 24, 2014 | 05:29 PM
unpazzo's Avatar
Registered Users
Default rectifier
When changing my old rectifier the wiring harness was melted so I went to hard wire it without the harness. I accidentally mixed up the 2 battery wires and when I hooked up the battery got a spark. Now the battery shows as charged but it won't even turn over do you think I fried the new rectifier?
Old Jun 24, 2014 | 05:49 PM
74demon's Avatar
No. I think you blew the main fuse.
Old Jun 24, 2014 | 05:55 PM
marc0011's Avatar
Agreed, main fuse. You'll find it under the plug for the starter relay.
Old Jun 24, 2014 | 06:03 PM
unpazzo's Avatar
Registered Users
I think I found the spare but don't know where the fuse is
Old Jun 24, 2014 | 06:08 PM
unpazzo's Avatar
Registered Users
Found it
Ok now it will run but only idle at 1 to 1500 on full choke
Old Jun 25, 2014 | 01:17 PM
marc0011's Avatar
If you have a multi meter, measure the voltage of the battery with the bike not running. You should have 12.8V to 13.0V. Start the bike and rev the bike up to 4,500 - 5,000 RPM. Measure the voltage going into the battery and you should have something in the area of 13.8V to 15V.
If you have less than that with the battery only, it needs to be charged. If you get less than 13.8V with the bike running, there is an issue with the charging system. It would either be RR, rectifier, and or battery. How old is the battery by the way?
Old Jun 25, 2014 | 04:17 PM
unpazzo's Avatar
Registered Users
Battery is 2 weeks old
Old Jun 25, 2014 | 04:19 PM
unpazzo's Avatar
Registered Users
When I hard wired it I only used 14 gauge wire could that be a problem?
Old Jun 25, 2014 | 07:25 PM
CorruptFile's Avatar
June 2013 ROTM
14 ga is fine. Does it rev okay?
graygeezer
Jul 31, 2011 02:33 AM
cbrsingleside
Apr 28, 2010 08:55 PM
rkgjr1981
F2 Tech
Apr 13, 2010 11:46 PM
falieson
Jan 22, 2010 12:40 AM
Junior
Aug 27, 2006 01:25 PM
