Rectifier
My battery, or so I thought, was acting up last year so I replaced it, but still had problems with it twice. I will ride for like 30 minutes or so, then stop and when i go to start my bike, it is as if my battery is dead. Luckily I have been with a riding buddy both time, so he push started me.
When I returned or got where I was going (another 30 minutes or more), and shut my bike off. Then hit the start button and it fired right up no problem. Leave it sit for a while, starts right up.
Could this be the rectifier? Or the "R/R", whatever that is?
Oxford do a really good battery charger, just stick it on and it will tell you the condition of the battery.
cant remeber the exact model number of mine but it does the trick. even if your battery is nackered it will tell you and then try and recover it.
had the rectifier go on my bike, i had the same symptoms, changed it and it sorted the problem out.
Battery currently is sitting in my house (dont have a trickle charger and im poor) because its winter so I dont leave it in my bike. But if several others have had the same issue and fixed it with that I might try it.
Are the Regulator and Rectifier one connected thing that people refer to them together? Or is just the Rectifier bad?
i just bought a r/r from a electrosport, very good customer service, new r/r looks great and has lots of thick heat sinking on it. a lot more heavy duty then the oem one. i would defiantly recommend getting it
http://www.electrosport.com/street-b...uper-duty.html
