Rear wheel dampener question
Old Apr 4, 2011 | 08:07 PM
alm70's Avatar
Default Rear wheel dampener question
While waiting for my new tires and sprockets to come in, I decided to look closer at the hub on the rear wheel. I was taking the sprocket off and noticed the whole flange or hub (part hte sprocket is attached to) moves about an 1/8". Does this make any sense? If I grab the sprocket and move the whole hub (or driven flange as it is called in the manual) it moves just a little. If the rubber dampeners inside needed to be replaced would this fix the movement...or should there be some movement.
I hope I explained this well enough...let me know if you need more info.
Thanks in advance...
Old Apr 4, 2011 | 09:22 PM
jeason15's Avatar
You have painted a perfect picture for us. what you are describing is called the Cush-drive system. it is how these bikes are designed to handle the stresses of torque and acceleration without causing damage to the metal parts of the wheel. it is functioning as advertised, and should not be a cause for concern.
Old Apr 8, 2011 | 03:39 PM
alm70's Avatar
Thanks for setting me straight jeason....I love this site.
95frankenF3
May 8, 2012 11:28 AM
929trf
Aug 13, 2011 10:27 AM
MUGENRUCKUS
Jun 9, 2010 10:54 AM
Abi
Aug 19, 2008 10:23 AM
ninetyfivehp
Jun 20, 2007 06:27 PM
