Rear shock swap
Old 10-18-2008 | 02:53 AM
powerban's Avatar
Default RE: Rear shock swap
The 600RR shock will definitely not fit on the F2/F3. The F4i shock works and raises the rear about an inch and a half. Its not bad. If you talk to MoreRR on CBRWorld, he says his best geometry was raising the rear about 37mm or so and lowering the front about 17mm. Thats a pretty drastic change but it works well for him and he's a bike designer/engineer/mechanic. Im not saying his word is the bible but you can do whatever you like. Getting the forks redone is around $150 but thats not including the valving and parts such as seals and fluid. I just did mine last weekend and all i paid was for two new sets of seal, dust seals, and a bottle of fluid. There's a great write up around somewhere on rebuilding and revalving your own forks. Its not hard. Just messy.
Old 10-18-2008 | 10:12 AM
suzuki2903's Avatar
after looking at a f4 shock as well, it looks almost like the f3 shock so im assuming there is no real performance advantages? other then it raises the rear up a little bit.
SneakyMcC
09-12-2011 05:54 AM
jtkardel
F2 Tech
24
04-02-2011 04:09 PM
njdjh2o
06-05-2008 05:38 PM
Loomis
04-18-2008 02:27 AM
Quick Reply: Rear shock swap
