Rear Shock Question
RE: Rear Shock Question
ORIGINAL: HurricaneForce
Would I see any performance or handling benefits if I put it into my 1987 CBR 600 F1?
Will it give you better performance?? Not likely. Its spring rate and valving is likely the same as your current shock. Unless you weigh ~140 lbs the stock spring really isn't made for you from a performance perspective. Another issue is that you're dealing with a shock that is 11 years old and is likely in dire need of reservicing/rebuilding. I doubt this shock has any spunk left in it as shocks (and forks) need to be serviced about every 12k miles. Many people skimp on this.
Would it be hard to install?
Another issue you will face is that the shocks are of different lengths. This will change the geometry of your bike (which isn't necessarily a bad thing) but it will also put the shock in a position (i.e. length) that it was not designed for.
Personally, I do NOT recommend using a shock that was not designed for your bike. But my perspective is performance riding. If that's not your priority than it may not be a big deal. I think you'd be much better off getting your stock shock reprung and revalved for your weight and properly set up.
Abad - as I was tearing my bike apart the other day, I noticed the front right fork seal is leaking a tiny bit, but enough.
I read what you wrote, and I'm willing to be that the forks or shock have not been serviced. So...
I'm sure I can do the forks myself, can you tell me what tools I'll need? What I'm super curious about, is the rear shock...
What can/do I do to service and get the most out of it?
