rear preload adjustment
Old Nov 22, 2013 | 09:31 AM
sportacer's Avatar
Registered Users
Default rear preload adjustment
Ok guys im trying to adjustment my rear preload because i need just a little more sag. I only have about 20mm and need 25 to 30mm. Problem is i cant get the preload adjuster to move at all. Is there a set screw or something im missing here?? By the way i have a 95 cbr f3.
Old Nov 22, 2013 | 09:47 AM
sjona2011's Avatar
youre talking about adjusting the spring tension, correct?
if so, the proper wrench will be your best friend...and a friend to lift up on the tail of the bike helps too.
Old Nov 22, 2013 | 09:50 AM
sportacer's Avatar
Registered Users
Yes thats correct. I have a preload tool for my zx6r. Thats what im trying to use. Is it a ramp type adjuster or threaded.
Old Nov 22, 2013 | 10:08 AM
coalminer frank's Avatar
If you dont have a friend to help lift the subframe up to get the weight off of the shock, try a scissor jack from a car. Put it between the tire and the subframe and just go enough to take the weight off of it. Make sure the top of the jack is on some metal and not plastic.
bigboi18184
Nov 2, 2010 09:16 AM
Mo777
Apr 9, 2009 06:59 PM
obxtoy93
Jan 7, 2007 02:04 PM
obxtoy93
Jan 6, 2007 07:15 PM
2wheels
Nov 7, 2006 12:46 PM
