Rear bearings
Old Apr 29, 2008 | 06:44 PM
shoemjay's Avatar
Default Rear bearings
Does anyone know how many bearings are in the rear wheel, Also where to buy them cheap. When replaceing the bearings should the rubber peices be replaced too. Where do you buy those rubber peices from.
My back wheel movesin all directions, its all around shaky, lots of movement(up,down, side to side) BEARINGS! Appreciate it.
Old Apr 29, 2008 | 09:13 PM
KidCr3nshaw's Avatar
Default RE: Rear bearings
Yeah Ronayers.com is good.
I get my stuff from Honda so there's no guesswork on my own (although I always have correct part #'s before I go to order them). In any case, it's not much for the whole load... it's like $30 in parts.
You'll need a cush drive bearing and seal, sprocket-side bearing/seal, and rotor side bearing/seal. Unless you get a kit you'll have to order each one as you only get what you order from OEM. If your parts guy DOES offer a kit, make sure to go over it real quick to make sure - 3 bearings (2 are the same, IIRC), and 3 seals (it may only be 2 seals, don't remember).
If you need any tips on installing them with a socket only, let me know.
Good luck.
Old Apr 29, 2008 | 10:48 PM
shoemjay's Avatar
Good looking out, im ganna check it out.
fangy
Aug 25, 2012 06:33 PM
Daniel.Hennessy@va.g
May 28, 2009 06:04 AM
Harry_T_Hamster
May 25, 2009 11:07 AM
akcbrf3
Feb 11, 2008 02:07 PM
Eckl
Jan 1, 2008 08:32 PM
