Quick Question
Old Mar 9, 2007 | 08:23 PM
knot55's Avatar
Default Quick Question
Anyone help? .If a battery is dead could it be a cause of a reg/rec getting really hot? Thanks
Old Mar 9, 2007 | 09:27 PM
transamlt1man's Avatar
Default RE: Quick Question
if your voltage regulator isnt working correctly it might not be charging the battery so yes.
Old Mar 9, 2007 | 10:08 PM
HAVOC's Avatar
yep its a very common problem with F2/F3/F4/900's .. so replace your regulator, charge your battery or buy a new one if its just completly wasted then you should be fine
Old Mar 10, 2007 | 04:53 PM
marc0011's Avatar
I would do a little checking with a meter first. The reg/rec could be really hot for a couple reasons;
1. The alternator is putting out too much power.
2. The battery is dead and the reg/rec is being overworked.
3. It could just be a bad reg/rec.
Here is a link that abadfish postedwith some instructions onhow to go through and test various components of the charging system. Reg/rec are little expensive and it doesn't hurt to do a couple tests before you go out and buy one.
http://cbrworld.net/forums/thread/140473.aspx
Old Mar 11, 2007 | 10:21 AM
knot55's Avatar
Thanks for the quick replys, very helpful .I need to buy a meter and start checking ,Thanks again
TattooguyF4i
Mar 31, 2010 12:39 PM
CBR_GreenMonster
Aug 13, 2009 08:00 AM
viva_brasil
Jun 9, 2008 04:38 AM
rke2121
Feb 6, 2008 05:45 PM
bboi
Jul 9, 2007 10:08 PM
