Quick question
Old Oct 9, 2009 | 07:42 AM
lizo74's Avatar
Default Quick question
Will riding at low revs, approx 3 to 4000 with the headlight on drain the battery quickly??
Old Oct 10, 2009 | 02:29 AM
pacemaker's Avatar
No, can't quite remember what the optimal rev for charging is (maybe 2000 rpm), but 3000 to 4000rpm is well over & it would not drain your battery quickly.
Me thinks you may have the start of the dreaded reg problem & like everyone else who has had it, your assuming it's the battery (has to be right, what else?). And like everyone else, your probably going to charge it, then buy a new one when that don't fix it. Do yourself a favour & have the reg checked out. Make sure the bike is warmed up as the reg faults start when it overheats.
Old Oct 14, 2009 | 04:28 PM
johnnyx's Avatar
2.5k will sustain the bike through the stator, 5k is optimal charging. Everything in between WILL charge, just more slowly. 3-4k is normal cruising range for just about all stock motorcycles, so if you're having a problem there, you definitely have a hardware failure.
Old Oct 15, 2009 | 08:15 AM
chuckbear's Avatar
+1
5k is optimal.
Find the charging system test on here and go to town. Let us know what you find out.
Old Oct 15, 2009 | 11:57 AM
abeer1's Avatar
It could be that you have a bad battery as well and it's not allowing it to charge properly.
Old Oct 15, 2009 | 12:23 PM
NYKnick1015's Avatar
my bike used to do that... i needed to get the battery recharged because its voltage levels was low
TattooguyF4i
Mar 31, 2010 12:39 PM
CBR_GreenMonster
Aug 13, 2009 08:00 AM
viva_brasil
Jun 9, 2008 04:38 AM
rke2121
Feb 6, 2008 05:45 PM
bboi
Jul 9, 2007 10:08 PM
