Questions about headlight and switch....
I discovered last night while riding that I have no high beam headlight. Well today I discovered that the prior owner basically straight wired a low beam. Well after tracing wiring, I am not getting any power to the wires to the headlight in either low or high beams. I looked through the wiring diagram and traced some wires. It looks as thought the swtich is bad. Am I correct that power feeds through the swtich and then to the headlight? If so, then the switch is just bad-no biggie, but if not, then I have some much bigger issues to work on.
Well I used the wiring diagram from the manual and basically traced the wiring from the fuse box back across to the headlight switch. to find the broken/cut wires. Are your running lights working ok on the front because they share some of the same wiring? I can not remember the wire colors coming out of the switch to test but I think they are blue and a black wire. I will look at mine again in the next day or so and try to help you through this.
Davidth93
Jul 16, 2009 12:22 AM
