Probably a Dumb Question!!
Old Jan 20, 2009 | 12:32 PM
ldv12's Avatar
Default Probably a Dumb Question!!
Ummm yeah so i just got my 97 f3 for $2000 but i need to replace the fork seals. Im about to do it myself, got the stands and all that BUT.....WHERE IN WORLD DO YOU PUT THE TRIPLE TREE STAND TO GET THE FRONT END UP? I feel like a dummy. The guys from Trex said the stand would work for my bike.
Any hints would be GREAT!!
Old Jan 20, 2009 | 12:40 PM
pontyhufc's Avatar
Default RE: Probably a Dumb Question!!
id say you got to take the fairing off. but someone else will tell you for sure.
Old Jan 21, 2009 | 09:48 AM
cajunlowrida's Avatar
If its a triple stand there is aloop on the lower clamp that a pin from the stand should go in. Unfortunatly to do this you have to take off the ram air duct which necessitates removal of the upper
Old Jan 21, 2009 | 07:07 PM
kwong2001's Avatar
You'll have to also remove the tank, and most of the airbox to remove the ram air inlet. Oh, and to remove the tank you'll need to pull the side parts of the tail section and the seat. Once you remove all that crap, I think all you have to do is unbolt the radiator mounts and you should be able to squeeze the ram air through. At least that's the way I did it...but that was a couple years ago.
Old Jan 21, 2009 | 07:23 PM
marc0011's Avatar
There is no loop on the lower triple clamp. I have always used a hoist setup through the neck on the frame to perform this task. Here is what I use to I tear down my bike. I don*t have any direct shots but you can see it in the back ground. It is an engine hoist (a.k.a. cherry picker) for cars which only costed $120 and another $8 for the straps.
Old Jan 21, 2009 | 08:27 PM
ldv12's Avatar
WhaT!!! all that just to lift the front end up to get the forks out! I just had to get the bike that you just could fit it into the lower tree like they say. Im callin TRex tomorrow....UGGGGGHHH. Lol
Thanks though guys. oh yeah and marc...homie big ups to you and all the work you do on your bike. FRESH 2 DEATH!!!!
Old Jan 21, 2009 | 09:13 PM
MrBomb's Avatar
dang that sounds like a lot of work to just lift the front end, i was thinking about getting that type of stand but not anymore
Old Jan 21, 2009 | 09:30 PM
marc0011's Avatar
Well, it isn*t as bad as it looks... could be considered a little excessive. If I am just working on the front end, then all you have to do is support the front end. I*ve got straps up and down mine because I took the rear end apart too. But I agree with you Idv12, you have already purchase the lift... it better damn well work!!!
If you looked at my pics though, I removed the triple clamp so there really isn*t a whole lot to support the bike with. I like to inspect the steering head bearings because for preventive maintanance because the grease gets old/dirty. By the way, there isn*t a whole lot of grease on the steering head bearings from the factory. About a week ago I worked on another forum member's F3 and there was next to no grease on the steering head bearings.
Old Jan 25, 2009 | 03:02 PM
ldv12's Avatar
Alright fellas,
I found/ created a solution to my triple tree stand problem. Marc...there actually is a hole for the pin to go into and kwong was right it is right on top of the air inlet. The honda guys sure did a bad job with this one because after lookin at it for a while im like ok well the inlet is only about an inch and a half past where i need it to be for me to use the stand. SOOOOO....this might be a lil drastic but i chopped off the extra inch and a half and what do u know the stand pops the front end right up. Dont know if that inch and change is gonna come back to bite me performance wise but just in case im gonna clamp it back on so its back to "normal".So MrBomb feel free to get the triple tree stand if u wanna go my route cuz "NOW" it works like a charm....I guess thats what happens when you watch too many episodes of macguyver!!!! LOL.
Old Jan 26, 2009 | 12:12 PM
kjohnson's Avatar
Remove your side panels.
Lift the front of the bikeby the forks with a stand
Place jackstands under the engine cases
Lower the front stand,making the front forks accessable.
Remove forks.
Simple.
smr96
Apr 26, 2010 10:14 PM
hrcentury21
Jun 25, 2009 07:31 AM
BStrand29
Aug 9, 2008 06:50 AM
Lone Ryder79
May 30, 2008 10:05 AM
sickshifter21
Jun 7, 2006 10:33 AM
