Picked up my first bike...
#22
#23
I went out and took the rest of the bike apart. I ended up sanding and painting the frame. I'll work on the gas tank either through the week or next weekend.
![Name: IMG_20110123_161841.jpg
Size: 48.0 KB](https://cbrforum.com/forum/attachments/cbr-600f3-17/51111d1501301133-picked-up-my-first-bike-img_20110123_161841.jpg)
Although I sanded the frame I expect it to chip as I ride the bike. If it doesn't work as well as I hope, I'll pull it back apart and send it off for powder-coating.
#25
#26
#27
Looks Dope!! If you buy the led integrated taillight from china its like 20 or 30 bucks. its a good buy imo. How do u plan on supporting the rear passenger seat? just curious.
Also, how'd you get prep the gas fill? i was going to disassemble mine and sand down the corners than throw some etch primer on it and hope it lasts.
#28
I'll more than likely go with an integrated tail light because I don't want the bulky tail lights, but I have a very nice stock 600rr light. That'll come after I mock the tail fairing up.
I prepped the tank by stripping it down to bare metal. It was probably overkill, but I wasn't sure what I was starting with. I then prepped the metal with self-etching primer. I then threw on a few coats of high build primer and sanded. I ended with 3-4 coats of color with a fairly light first coat, followed by 4 coats of clear. That should give me enough clear to color sand some of the orange peel out (it's a little colder than I'd like for painting).
As for the seat, I'm going to break out the welder and fab up whatever bracing I need. I'm already going to raise the frame up to help the tail fairing lines match up a little better with the bike. The tail fairing should get here sometime this week so I can get started on that.
I think the next project is going to be tackling the clutch before I start putting the bike back together.
#30
